Combining Logic and Probabilities for Discovering Mappings between Taxonomies (short paper) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we investigate a principled approach for defining and discovering probabilistic mappings between two taxonomies. First, we compare two ways of modeling probabilistic mappings which are compatible with the logical constraints declared in each taxonomy. Then we describe a generate and test algorithm which minimizes the number of calls to the probability estimator for determining those mappings whose probability exceeds a certain threshold. Finally, we provide an experimental analysis of this approach.
Fichier non déposé
hal-00953266 , version 1 (28-02-2014)
  • HAL Id : hal-00953266 , version 1
Remi Tournaire, Jean-Marc Petit, Marie-Christine Rousset, Alexandre Termier. Combining Logic and Probabilities for Discovering Mappings between Taxonomies (short paper). 7th Extented Semantic Web Conference, 2010, Heraklion, Greece. pp.not available. ⟨hal-00953266⟩
347 Consultations
0 Téléchargements
