Systems Verification using Randomized Exploration of Large State Spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Exhaustive verification often suffers from the state-explosion problem, where the reachable state space is too large to fit in main memory. For this reason, and because of disk swapping, once the main memory is full very little progress is made, and the process is not scalable. To alleviate this, partial verification methods have been proposed, some based on randomized exploration, mostly in the form of random walks. In this paper, we enhance partial, randomized state-space exploration methods with the concept of resource-awareness: the exploration algorithm is made aware of the limits on resources, in particular memory and time. We present a memory-aware algorithm that by design never stores more states than those that fit in main memory. We also propose criteria to compare this algorithm with similar other algorithms. We study properties of such algorithms both theoretically on simple classes of state spaces and experimentally on some preliminary case studies.
Abed-Vincent-SPIN-2008.pdf (317.03 Ko) Télécharger le fichier
hal-00953617 , version 1 (28-02-2014)
  • HAL Id : hal-00953617 , version 1
Nazha Abed, Stavros Tripakis, Jean-Marc Vincent. Systems Verification using Randomized Exploration of Large State Spaces. SPIN, 2008, Los Angeles. ⟨hal-00953617⟩
119 Consultations
53 Téléchargements
