Can we use perfect simulation for non-monotonic Markovian systems ? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Ana Bušić
Bruno Gaujal
Jean-Marc Vincent
Simulation approaches are alternative methods to estimate the stationary be- havior of stochastic systems by providing samples distributed according to the stationary distribution, even when it is impossible to compute this distribution numerically. Propp and Wilson used a backward coupling to derive a simu- lation algorithm providing perfect sampling (i.e. which distribution is exactly stationary) of the state of discrete time finite Markov chains. Here, we adapt their algorithm by showing that, under mild assumptions, backward coupling can be used over two simulation trajectories only.
Roadef-2008.pdf (67.45 Ko) Télécharger le fichier
hal-00953636 , version 1 (25-03-2014)
  • HAL Id : hal-00953636 , version 1
Vandy Berten, Ana Bušić, Bruno Gaujal, Jean-Marc Vincent. Can we use perfect simulation for non-monotonic Markovian systems ?. ROADEF, 2008, Clermont-Ferrand. ⟨hal-00953636⟩
288 Consultations
58 Téléchargements
