From Database to Web multimedia documents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Multimedia Tools and Applications Année : 2003
This paper deals with the integration of multimedia and database technologies in order to describe web multimedia documents. We present a middleware to seamlessly handle database accesses as well as compositional, spatial and temporal constraints related to data presentation. Our approach is based on the concept of Templates. A template is a logical presentation unit that merge database queries with layout specifications. We choose an XML and SMIL approach to implement template. Template definition and invocation are mapped into a XML DTD. Each template is then translated into a SMIL document. In this paper, we give an example to show the advantages of our approach.
MMTA_final.pdf (307.42 Ko) Télécharger le fichier
hal-00953813 , version 1 (03-03-2014)
  • HAL Id : hal-00953813 , version 1
Philippe Mulhem, Hervé Martin. From Database to Web multimedia documents. Multimedia Tools and Applications, 2003, 20 (3), pp.263--282. ⟨hal-00953813⟩
116 Consultations
111 Téléchargements
