Well-posedness of a conservation law with non-local flux arising in traffic flow modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2016
We prove the existence and stability of entropy weak solutions of a scalar conservation law with non-local flux arising in traffic flow modeling. The result is obtained providing accurate L\infty , BV and L1 estimates for the sequence of approximate solutions constructed by an adapted Lax-Friedrichs scheme.
BlandinGoatin.pdf (339.2 Ko) Télécharger le fichier
hal-00954527 , version 1 (03-03-2014)
Sebastien Blandin, Paola Goatin. Well-posedness of a conservation law with non-local flux arising in traffic flow modeling. Numerische Mathematik, 2016, ⟨10.1007/s00211-015-0717-6⟩. ⟨hal-00954527⟩
623 Consultations
960 Téléchargements
