A Uniform Programming Language for Implementing XML Standards - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose X-Fun, a higher-order functional programming language for transforming XML documents based on path queries. We present a lean formal model for the operational semantics of X-Fun based on lambda calculus and provide an in-memory implementation on top a chosen XPath evaluator. We also discuss compilers from XSLT, XQuery and XProc into X-Fun, which leads us to in-memory implementations of these XML standards with large coverage and high efficiency.
A long version is available here.
0.pdf (296.8 Ko) Télécharger le fichier
hal-00954692 , version 1 (06-10-2014)
  • HAL Id : hal-00954692 , version 1
Pavel Labath, Joachim Niehren. A Uniform Programming Language for Implementing XML Standards. 41st SOFSEM: International Conference on Current Trends in Theory and Practice of Computer Science, Jan 2015, Pec pod Sněžkou, Czech Republic. ⟨hal-00954692⟩
376 Consultations
212 Téléchargements
