Locality optimization on a NUMA architecture for hybrid LU factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
We study the impact of non-uniform memory accesses (NUMA) on the solution of dense general linear systems using an LU factorization algorithm. In particular we illustrate how an appropriate placement of the threads and memory on a NUMA architecture can improve the performance of the panel factorization and consequently accelerate the global LU factorization. We apply these placement strategies and present performance results for a hybrid multicore/GPU LU algorithm as it is implemented in the public domain library MAGMA.
RR-8497.pdf (488.27 Ko) Télécharger le fichier
hal-00957673 , version 1 (10-03-2014)
  • HAL Id : hal-00957673 , version 1
Adrien Rémy, Marc Baboulin, Masha Sosonkina, Brigitte Rozoy. Locality optimization on a NUMA architecture for hybrid LU factorization. [Research Report] RR-8497, INRIA. 2014. ⟨hal-00957673⟩
493 Consultations
287 Téléchargements
