Lower bounds for sparse matrix vector multiplication on hypercubic networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1998
In this paper we consider the problem of computing on a local memory machine the product y = Ax,where A is a random n×n sparse matrix with Θ (n) nonzero elements. To study the average case communication cost of this problem, we introduce four different probability measures on the set of sparse matrices. We prove that on most local memory machines with p processors, this computation requires Ω ((n/p) \log p) time on the average. We prove that the same lower bound also holds, in the worst case, for matrices with only 2n or 3n nonzero elements.
dm020103.pdf (164.2 Ko) Télécharger le fichier
hal-00958901 , version 1 (13-03-2014)
Giovanni Manzini. Lower bounds for sparse matrix vector multiplication on hypercubic networks. Discrete Mathematics and Theoretical Computer Science, 1998, Vol. 2, pp.35-47. ⟨10.46298/dmtcs.249⟩. ⟨hal-00958901⟩
Collections
TDS-MACS
79 Consultations
717 Téléchargements
