Unification of Higher-order Patterns modulo Simple Syntactic Equational Theories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2000
We present an algorithm for unification of higher-order patterns modulo simple syntactic equational theories as defined by Kirchner [14]. The algorithm by Miller [17] for pattern unification, refined by Nipkow [18] is first modified in order to behave as a first-order unification algorithm. Then the mutation rule for syntactic theories of Kirchner [13,14] is adapted to pattern E-unification. If the syntactic algorithm for a theory E terminates in the first-order case, then our algorithm will also terminate for pattern E-unification. The result is a DAG-solved form plus some equations of the form λ øverlinex.F(øverlinex) = λ øverlinex. F(øverlinex^π ) where øverlinex^π is a permutation of øverlinex When all function symbols are decomposable these latter equations can be discarded, otherwise the compatibility of such equations with the solved form remains open.
dm040102.pdf (182.49 Ko) Télécharger le fichier
hal-00958942 , version 1 (13-03-2014)
Alexandre Boudet. Unification of Higher-order Patterns modulo Simple Syntactic Equational Theories. Discrete Mathematics and Theoretical Computer Science, 2000, Vol. 4 no. 1 (1), pp.11-30. ⟨10.46298/dmtcs.270⟩. ⟨hal-00958942⟩
77 Consultations
694 Téléchargements
