A permutations representation that knows what "Eulerian" means - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2001
Eulerian numbers (and ''Alternate Eulerian numbers'') are often interpreted as distributions of statistics defined over the Symmetric group. The main purpose of this paper is to define a way to represent permutations that provides some other combinatorial interpretations of these numbers. This representation uses a one-to-one correspondence between permutations and the so-called \emphsubexceedant functions.
dm040203.pdf (59.18 Ko) Télécharger le fichier
hal-00958950 , version 1 (13-03-2014)
Roberto Mantaci, Fanja Rakotondrajao. A permutations representation that knows what "Eulerian" means. Discrete Mathematics and Theoretical Computer Science, 2001, Vol. 4 no. 2 (2), pp.101-108. ⟨10.46298/dmtcs.271⟩. ⟨hal-00958950⟩
163 Consultations
1648 Téléchargements
