Probabilistic Analysis of Carlitz Compositions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2002
Using generating functions and limit theorems, we obtain a stochastic description of Carlitz compositions of large integer n (i.e. compositions two successive parts of which are different). We analyze: the number M of parts, the number of compositions T(m,n) with m parts, the distribution of the last part size, the correlation between two successive parts, leading to a Markov chain. We describe also the associated processes and the limiting trajectories, the width and thickness of a composition. We finally present a typical simulation. The limiting processes are characterized by Brownian Motion and some discrete distributions.
Mots clés
dm050105.pdf (232.17 Ko) Télécharger le fichier
hal-00958973 , version 1 (13-03-2014)
Guy Louchard, Helmut Prodinger. Probabilistic Analysis of Carlitz Compositions. Discrete Mathematics and Theoretical Computer Science, 2002, Vol. 5, pp.71-96. ⟨10.46298/dmtcs.302⟩. ⟨hal-00958973⟩
Collections
TDS-MACS
40 Consultations
727 Téléchargements
