A bijection between planar constellations and some colored Lagrangian trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2003
Constellations are colored planar maps that generalize different families of maps (planar maps, bipartite planar maps, bi-Eulerian planar maps, planar cacti, ...) and are strongly related to factorizations of permutations. They were recently studied by Bousquet-Mélou and Schaeffer who describe a correspondence between these maps and a family of trees, called Eulerian trees. In this paper, we derive from their result a relationship between planar constellations and another family of trees, called stellar trees. This correspondence generalizes a well known result for planar cacti, and shows that planar constellations are colored Lagrangian objects (that is objects that can be enumerated by the Good-Lagrange formula). We then deduce from this result a new formula for the number of planar constellations having a given face distribution, different from the formula one can derive from the results of Bousquet-Mélou and Schaeffer, along with systems of functional equations for the generating functions of bipartite and bi-Eulerian planar maps enumerated according to the partition of faces and vertices.
dm060102.pdf (202.04 Ko) Télécharger le fichier
hal-00958985 , version 1 (13-03-2014)
Cedric Chauve. A bijection between planar constellations and some colored Lagrangian trees. Discrete Mathematics and Theoretical Computer Science, 2003, Vol. 6 no. 1 (1), pp.13-40. ⟨10.46298/dmtcs.340⟩. ⟨hal-00958985⟩
Collections
TDS-MACS
42 Consultations
759 Téléchargements
