Local path planning for mobile robots based on intermediate objectives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Robotica Année : 2014
This paper presents a path planning algorithm for autonomous navigation of non-holonomic mobile robots in complex environments. The irregular contour of obstacles is represented by segments. The goal of the robot is to move towards a known target while avoiding obstacles. The velocity constraints, robot kinematic model and non-holonomic constraint are considered in the problem. The optimal path planning problem is formulated as a constrained receding horizon planning problem and the trajectory is obtained by solving an optimal control problem with constraints. Local minima are avoided by choosing intermediate objectives based on the real time environment.
Automatique
local_path_planning.pdf (455.02 Ko) Télécharger le fichier
hal-00960019 , version 1 (01-04-2014)
Yingchong Ma, Gang Zheng, Wilfrid Perruquetti, Zhaopeng Qiu. Local path planning for mobile robots based on intermediate objectives. Robotica, 2014, pp.1-15. ⟨10.1017/S0263574714000186⟩. ⟨hal-00960019⟩
309 Consultations
1483 Téléchargements
