Generalized connected domination in graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2006
As a generalization of connected domination in a graph G we consider domination by sets having at most k components. The order γ _c^k (G) of such a smallest set we relate to γ _c(G), the order of a smallest connected dominating set. For a tree T we give bounds on γ _c^k (T) in terms of minimum valency and diameter. For trees the inequality γ _c^k (T)≤ n-k-1 is known to hold, we determine the class of trees, for which equality holds.
dm080104.pdf (106.14 Ko) Télécharger le fichier
hal-00961101 , version 1 (19-03-2014)
Mekkia Kouider, Preben Dahl Vestergaard. Generalized connected domination in graphs. Discrete Mathematics and Theoretical Computer Science, 2006, Vol. 8, pp.57-64. ⟨10.46298/dmtcs.373⟩. ⟨hal-00961101⟩
91 Consultations
1069 Téléchargements
