On the computability of the topological entropy of subshifts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2006
We prove that the topological entropy of subshifts having decidable language is uncomputable in the following sense: For no error bound less than 1/4 does there exists a program that, given a decision procedure for the language of a subshift as input, will approximate the entropy of the subshift within the error bound. In addition, we prove that not only is the topological entropy of sofic shifts computable to arbitary precision (a well-known fact), but all standard comparisons of the topological entropy with rational numbers are decidable.
456-1734-1-PB.pdf (159.62 Ko) Télécharger le fichier
hal-00961115 , version 1 (20-03-2014)
Jakob Grue Simonsen. On the computability of the topological entropy of subshifts. Discrete Mathematics and Theoretical Computer Science, 2006, Vol. 8, pp.83--95. ⟨10.46298/dmtcs.365⟩. ⟨hal-00961115⟩
Collections
TDS-MACS
65 Consultations
1230 Téléchargements
