Robot Learning from Unlabelled Teaching Signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
At home, workplaces or schools, an increasing amount of intelligent robotic systems are starting to be able to help us in our daily life. A key feature in these new domains is the close interaction between people and robots. In particular, such robotic systems need to be teachable by non-technical users, i.e. programmable for new tasks in novel environments through intuitive, flexible and personalized interactions. Specifically, the challenge we address in this work is how a robot learning a new task can be instructed by a human using its own preferred teaching signals, where the mapping between these signals and their meaning is unknown to the robot. For example, different users may use different languages, words, interjections, gestures or even brain signals to mean "good" or "bad".
hripioneers2014.pdf (70.38 Ko) Télécharger le fichier
hal-00963725 , version 1 (24-03-2014)
  • HAL Id : hal-00963725 , version 1
Jonathan Grizou, Manuel Lopes, Pierre-Yves Oudeyer. Robot Learning from Unlabelled Teaching Signals. HRI 2014 Pioneers Workshop, Mar 2014, Bielefeld, Germany. ⟨hal-00963725⟩
303 Consultations
316 Téléchargements
