A perfect sampling algorithm of random walks with forbidden arcs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
Stéphane Durand
Florence Perronnin
Jean-Marc Vincent
In this paper we show how to construct an algorithm to sample the stationary distribution of a random walk over a grid with forbidden arcs. This algorithm combines the rejection method and coupling from the past of a set of trajectories of the Markov chain that generalizes the classical sandwich approach. We also provide a complexity analysis of this approach in several cases showing a coupling time that is logarithmic in the size of the grid, when no arc is forbidden, and an experimental study of its performance.
rr.pdf (565.24 Ko) Télécharger le fichier
hal-00964098 , version 1 (24-03-2014)
  • HAL Id : hal-00964098 , version 1
Stéphane Durand, Bruno Gaujal, Florence Perronnin, Jean-Marc Vincent. A perfect sampling algorithm of random walks with forbidden arcs. [Research Report] RR-8504, INRIA. 2014, pp.23. ⟨hal-00964098⟩
189 Consultations
468 Téléchargements
