Computation of L_⊕ for several cubic Pisot numbers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2007
In this article, we are dealing with β-numeration, which is a generalization of numeration in a non-integer base. We consider the class of simple Parry numbers such that dβ(1) = 0.k1d-1 kd with d ∈ ℕ, d ≥ 2 and k1 ≥ kd ≥ 1. We prove that these elements define Rauzy fractals that are stable under a central symmetry. We use this result to compute, for several cases of cubic Pisot units, the maximal length among the lengths of the finite β-fractional parts of sums of two β-integers, denoted by L_⊕. In particular, we prove that L_⊕ = 5 in the Tribonacci case.
665-2330-1-PB.pdf (926.23 Ko) Télécharger le fichier
hal-00966525 , version 1 (26-03-2014)
Julien Bernat. Computation of L_⊕ for several cubic Pisot numbers. Discrete Mathematics and Theoretical Computer Science, 2007, Vol. 9 no. 2 (2), pp.175--193. ⟨10.46298/dmtcs.405⟩. ⟨hal-00966525⟩
88 Consultations
775 Téléchargements
