Deep Syntax Annotation of the Sequoia French Treebank - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We define a deep syntactic representation scheme for French, which abstracts away from surface syntactic variation and diathesis alternations, and describe the annotation of deep syntactic representations on top of the surface dependency trees of the Sequoia corpus. The resulting deep-annotated corpus, named DEEP - SEQUOIA, is freely available, and hopefully useful for corpus linguistics studies and for training deep analyzers to prepare semantic analysis.
deep_sequoia.final_with_keywords.pdf (218.1 Ko) Télécharger le fichier
hal-00969191 , version 1 (02-04-2014)
hal-00969191 , version 2 (03-04-2014)
  • HAL Id : hal-00969191 , version 2
Marie Candito, Guy Perrier, Bruno Guillaume, Corentin Ribeyre, Karen Fort, et al.. Deep Syntax Annotation of the Sequoia French Treebank. International Conference on Language Resources and Evaluation (LREC), May 2014, Reykjavik, Iceland. ⟨hal-00969191v2⟩
597 Consultations
1086 Téléchargements
