Interaction properties of relational periods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2008
Vesa Halava
  • Fonction : Auteur
  • PersonId : 860207
Tero Harju
  • Fonction : Auteur
  • PersonId : 860208
Tomi Kärki
  • Fonction : Auteur
  • PersonId : 860209
We consider relational periods where the relation is a compatibility relation on words induced by a relation on letters. We introduce three types of periods, namely global, external and local relational periods, and we compare their properties by proving variants of the theorem of Fine and Wilf for these periods.
630-3214-1-PB-1.pdf (239.39 Ko) Télécharger le fichier
hal-00972304 , version 1 (03-04-2014)
Vesa Halava, Tero Harju, Tomi Kärki. Interaction properties of relational periods. Discrete Mathematics and Theoretical Computer Science, 2008, Vol. 10 no. 1 (1), pp.87--111. ⟨10.46298/dmtcs.419⟩. ⟨hal-00972304⟩
Collections
TDS-MACS
44 Consultations
728 Téléchargements
