Spanning forests on the Sierpinski gasket
We study the number of spanning forests on the Sierpinski gasket SGd(n) at stage n with dimension d equal to two, three and four, and determine the asymptotic behaviors. The corresponding results on the generalized Sierpinski gasket SGd;b(n) with d = 2 and b = 3 ; 4 are obtained. We also derive upper bounds for the asymptotic growth constants for both SGd and SG2,b.
Mathématique discrète [cs.DM]
