A Low-cost Transparent Electric Field Sensor for 3D Interaction on Mobile Devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We contribute a thin, transparent, and low-cost design for electric field sensing, allowing for 3D finger and hand tracking, as well as in-air gestures on mobile devices. Our approach requires no direct instrumentation of the hand or body, and is non-optical, allowing for a compact form-factor that is resilient to ambient illumination. Our simple driver electronics are based on an off-the-shelf chip that removes the need for building custom analog electronics. We describe the design of our transparent electrode array, and present a machine learning algorithm for mapping from signal measurements at the receivers to 3D positions. We demonstrate non-contact motion gestures, and precise 3D hand and finger localization. We conclude by discussing limitations and future work.
paper2010.pdf (862.6 Ko) Télécharger le fichier
Format : Figure, Image
hal-00973234 , version 1 (04-04-2014)
  • HAL Id : hal-00973234 , version 1
Mathieu Le Goc, Stuart Taylor, Shahram Izadi, Cem Keskin. A Low-cost Transparent Electric Field Sensor for 3D Interaction on Mobile Devices. Proceedings of the 2014 Annual Conference on Human Factors in Computing Systems (CHI 2014), Apr 2014, Toronto, Canada. ⟨hal-00973234⟩
369 Consultations
2653 Téléchargements
