Multi-Trial Guruswami--Sudan Decoding for Generalised Reed--Solomon Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Designs, Codes and Cryptography Année : 2014
An iterated refinement procedure for the Guruswami--Sudan list decoding algorithm for Generalised Reed--Solomon codes based on Alekhnovich's module minimisation is proposed. The method is parametrisable and allows variants of the usual list decoding approach. In particular, finding the list of closest codewords within an intermediate radius can be performed with improved average-case complexity while retaining the worst-case complexity. We provide a detailed description of the module minimisation, reanalysing the Mulders--Storjohann algorithm and drawing new connections to both Alekhnovich's algorithm and Lee--O'Sullivan's. Furthermore, we show how to incorporate the re-encoding technique of Kötter and Vardy into our iterative algorithm.
hal-arxiv20140409.pdf (327.35 Ko) Télécharger le fichier
hal-00975927 , version 1 (09-04-2014)
Johan Sebastian Rosenkilde Nielsen, Alexander Zeh. Multi-Trial Guruswami--Sudan Decoding for Generalised Reed--Solomon Codes. Designs, Codes and Cryptography, 2014, pp.1-21. ⟨10.1007/s10623-014-9951-7⟩. ⟨hal-00975927⟩
232 Consultations
99 Téléchargements
