A New Robust Approach for Highway Traffic Density Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fabio Morbidi
Luis Leon Ojeda
  • Fonction : Auteur
  • PersonId : 929661
Iker Bellicot
  • Fonction : Auteur
  • PersonId : 955288
In this paper we present a robust mode selector for the uncertain graph-constrained Switching Mode Model (SMM), which we use to describe the highway traffic density evolution. Assuming an uncertain speed of the congestion wave, the proposed selector relies on a transition digraph suitably incorporating the present and historical statistical traffic information, to determine the most probable current mode of the SMM. Its effectiveness is demonstrated on the problem of traffic density reconstruction via a switching observer, in an instrumented 2.2 km highway section of Grenoble south ring in France.
Automatique
MoOjCaBe_ECC14.pdf (545.41 Ko) Télécharger le fichier
hal-00979684 , version 1 (16-04-2014)
  • HAL Id : hal-00979684 , version 1
Fabio Morbidi, Luis Leon Ojeda, Carlos Canudas de Wit, Iker Bellicot. A New Robust Approach for Highway Traffic Density Estimation. ECC 2014 - 13th European Control Conference, Jun 2014, Strasbourg, France. pp.2576-2580. ⟨hal-00979684⟩
7442 Consultations
786 Téléchargements
