Cooperative human-robot haptic navigation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stefano Scheggi
  • Fonction : Auteur correspondant
  • PersonId : 954115
Connectez-vous pour contacter l'auteur
Marco Aggravi
  • Fonction : Auteur
  • PersonId : 955291
Fabio Morbidi
Domenico Prattichizzo
  • Fonction : Auteur
  • PersonId : 954116
This paper proposes a novel use of haptic feedback for human navigation with a mobile robot. Assuming that a path-planner has provided a mobile robot with an obstacle-free trajectory, the vehicle must steer the human from an initial to a desired target position by only interacting with him/her via a custom-designed vibro-tactile bracelet. The subject is free to decide his/her own pace and a warning vibrational signal is generated by the bracelet only when a large deviation with respect to the planned trajectory is detected by the vision sensor on-board the robot. This leads to a cooperative navigation system that is less intrusive, more flexible and easy-to-use than the ones existing in literature. The effectiveness of the proposed system is demonstrated via extensive real-world experiments.
Automatique
ScAgMoPr_ICRA14.pdf (469.42 Ko) Télécharger le fichier
hal-00979696 , version 1 (16-04-2014)
  • HAL Id : hal-00979696 , version 1
Stefano Scheggi, Marco Aggravi, Fabio Morbidi, Domenico Prattichizzo. Cooperative human-robot haptic navigation. ICRA 2014 - IEEE International Conference on Robotics and Automation, May 2014, Hong Kong, China. pp.2693-2698. ⟨hal-00979696⟩
276 Consultations
516 Téléchargements
