Efficient repeat finding in sets of strings via suffix arrays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2013
We consider two repeat finding problems relative to sets of strings: (a) Find the largest substrings that occur in every string of a given set; (b) Find the maximal repeats in a given string that occur in no string of a given set. Our solutions are based on the suffix array construction, requiring O(m) memory, where m is the length of the longest input string, and O(n &log;m) time, where n is the the whole input size (the sum of the length of each string in the input). The most expensive part of our algorithms is the computation of several suffix arrays. We give an implementation and experimental results that evidence the efficiency of our algorithms in practice, even for very large inputs.
2130-7867-1-PB.pdf (158.95 Ko) Télécharger le fichier
hal-00980753 , version 1 (18-04-2014)
Pablo Barenbaum, Verónica Becher, Alejandro Deymonnaz, Melisa Halsband, Pablo Ariel Heiber. Efficient repeat finding in sets of strings via suffix arrays. Discrete Mathematics and Theoretical Computer Science, 2013, Vol. 15 no. 2 (2), pp.59--70. ⟨10.46298/dmtcs.597⟩. ⟨hal-00980753⟩
Collections
TDS-MACS
195 Consultations
1007 Téléchargements
