Computing periods of rational integrals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2016
A period of a rational integral is the result of integrating, with respect to one or several variables, a rational function over a closed path. This work focuses particularly on periods depending on a parameter: in this case the period under consideration satisfies a linear differential equation, the Picard-Fuchs equation. I give a reduction algorithm that extends the Griffiths-Dwork reduction and apply it to the computation of Picard-Fuchs equations. The resulting algorithm is elementary and has been successfully applied to problems that were previously out of reach.
arxiv.article.pdf (611.3 Ko) Télécharger le fichier
hal-00981114 , version 1 (20-04-2014)
hal-00981114 , version 2 (06-05-2014)
hal-00981114 , version 3 (31-08-2015)
Pierre Lairez. Computing periods of rational integrals. Mathematics of Computation, 2016, 85, pp.1719-1752. ⟨10.1090/mcom/3054⟩. ⟨hal-00981114v3⟩
310 Consultations
577 Téléchargements
