Border Basis relaxation for polynomial optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2015
Marta Abril Bucero
  • Fonction : Auteur
  • PersonId : 935724
Bernard Mourrain
A relaxation method based on border basis reduction which improves the efficiency of Lasserre's approach is proposed to compute the optimum of a polynomial function on a basic closed semi algebraic set. A new stopping criterion is given to detect when the relaxation sequence reaches the minimum, using a sparse flat extension criterion. We also provide a new algorithm to reconstruct a finite sum of weighted Dirac measures from a truncated sequence of moments, which can be applied to other sparse reconstruction problems. As an application, we obtain a new algorithm to compute zero-dimensional minimizer ideals and the minimizer points or zero-dimensional G-radical ideals. Experimentations show the impact of this new method on significant benchmarks.
jsc-bbr-rev.pdf (297.71 Ko) Télécharger le fichier
hal-00981546 , version 1 (22-04-2014)
hal-00981546 , version 2 (23-06-2014)
hal-00981546 , version 3 (21-08-2015)
Paternité - Pas d'utilisation commerciale
Marta Abril Bucero, Bernard Mourrain. Border Basis relaxation for polynomial optimization. Journal of Symbolic Computation, 2015, 74, pp.378-399. ⟨10.1016/j.jsc.2015.08.004⟩. ⟨hal-00981546v3⟩
383 Consultations
332 Téléchargements
