Multi-Agent Assumption-based Planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
The purpose of this paper is to introduce a dialectical theory for plan synthesis based on a multi-agent approach. This approach is a promising way to devise systems based on agent planners in which the production of a global shared plan is obtained by conjecture/refutation cycles. Contrary to classical approaches, our contribution relies on agents' dialectical reasoning: in order to take into account partial knowledge and heterogeneous skills of agents, we propose to consider the planning problem as a defeasible reasoning where agents exchange proposals and counter-proposals and are able to conjecture i.e., formulate plan steps based on hypothetical states of the world. The dialogue between agents is a joint investigation process allowing agents to progressively prune objections, solve conjectures and elaborate solutions step by step.
pellier05a.pdf (45.49 Ko) Télécharger le fichier
hal-00981710 , version 1 (22-04-2014)
hal-00981710 , version 2 (22-04-2014)
  • HAL Id : hal-00981710 , version 2
Damien Pellier, Humbert Fiorino. Multi-Agent Assumption-based Planning. International Joint Conference on Artificial Intelligence, Jul 2005, Edinburgh, United Kingdom. pp.1717-1718. ⟨hal-00981710v2⟩
169 Consultations
117 Téléchargements
