A Benchmark-based Performance Model for Memory-bound HPC Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The increasing computation capability of servers comes with a dramatic increase of their complexity through many cores, multiple levels of caches and NUMA architectures. Exploiting the computing power is increasingly harder and programmers need ways to understand the performance behavior. We present an innovative approach for predicting the performance of memory-bound multi-threaded applications. It relies on micro-benchmarks and a compositional model, combining measures of micro-benchmarks in order to model larger codes. Our memory model takes into account cache sizes and cache coherence protocols, having a large impact on performance of multi-threaded codes. Applying this model to real world HPC kernels shows that it can predict their performance with good accuracy, helping taking optimization decisions to increase application's performance.
benchmark_based_memory_model.pdf (221.46 Ko) Télécharger le fichier
hal-00985598 , version 1 (30-04-2014)
Bertrand Putigny, Brice Goglin, Denis Barthou. A Benchmark-based Performance Model for Memory-bound HPC Applications. International Conference on High Performance Computing & Simulation (HPCS 2014), Jul 2014, Bologna, Italy. ⟨10.1109/HPCSim.2014.6903790⟩. ⟨hal-00985598⟩
283 Consultations
783 Téléchargements
