OpenCV WebCam Applications in an Arduino-based Rover - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we design and implement Arduino-based Rovers with characteristics of re-programmability, modularity in terms of type and number of components, communication capability, equipped with motion support and capability to exploit information both from the surrounding and from other wireless devices. These latter can be homogeneous devices (i.e. others similar rovers) and heterogeneous devices (i.e. laptops, smartphones, etc.). We propose a Behavioral Algorithm that is implemented on our devices in order to supply a proof-of-concept of the e ectiveness of a Detection task. Speci cally, we implement the "Object Detection" and "Face Recognition" techniques based on OpenCV and we detail the modi cations necessary to work on distributed devices. We show the e ectiveness of the controlled mobility concept in order to accomplish a task, both in a centralized way (i.e. driven by a central computer that assign the task) and in a totally distributed fashion, in cooperation with other Rovers. We also highlight the limitations of similar devices required to accomplish speci c tasks and their potentiality.
WebCamAppl-Wisarn.pdf (1.2 Mo) Télécharger le fichier
hal-00985946 , version 1 (18-07-2014)
  • HAL Id : hal-00985946 , version 1
Valeria Loscrì, Nathalie Mitton, Emilio Compagnone. OpenCV WebCam Applications in an Arduino-based Rover. International Workshop on Wireless Sensor, Actuator and Robot Networks (WiSARN), Jun 2014, Benidorm, Spain. ⟨hal-00985946⟩
Collections
INRIA INRIA2
422 Consultations
4307 Téléchargements
