Comments on Finite-time Stability of Time-Delay Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2014
Recently proposed conditions on finite-time stability in time-delay systems are revisited and it is shown that they are incorrect. General comments on possibility of finite-time convergence in time-delay systems and a necessary condition are given.
Note_FTS_time_delay.pdf (195.44 Ko) Télécharger le fichier
hal-00986004 , version 1 (30-04-2014)
Denis Efimov, Andrey Polyakov, Emilia Fridman, Wilfrid Perruquetti, Jean-Pierre Richard. Comments on Finite-time Stability of Time-Delay Systems. Automatica, 2014, 50 (7), pp.1944-1947. ⟨10.1016/j.automatica.2014.05.010⟩. ⟨hal-00986004⟩
344 Consultations
715 Téléchargements
