Interval estimation for systems with unknown input delays and gains
The estimation problem of a system with unknown time-delay and unknown input gains is considered. The interval observation technique is applied in order to obtain guaranteed interval of the system state. The proposed approach can be applied to linear delay systems and nonlinear time-delay systems in the output canonical form. The theoretical results are supported by numerical simulation and demonstration on example of thermic application.
Automatique
