Number of connected spanning subgraphs on the Sierpinski gasket - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2009
We study the number of connected spanning subgraphs f(d,b) (n) on the generalized Sierpinski gasket SG(d,b) (n) at stage n with dimension d equal to two, three and four for b = 2, and layer b equal to three and four for d = 2. The upper and lower bounds for the asymptotic growth constant, defined as zSG(d,b) = lim(v ->infinity) ln f(d,b)(n)/v where v is the number of vertices, on SG(2,b) (n) with b = 2, 3, 4 are derived in terms of the results at a certain stage. The numerical values of zSG(d,b) are obtained.
992-4084-1-PB.pdf (202.99 Ko) Télécharger le fichier
hal-00988182 , version 1 (07-05-2014)
Shu-Chiuan Chang, Lung-Chi Chen. Number of connected spanning subgraphs on the Sierpinski gasket. Discrete Mathematics and Theoretical Computer Science, 2009, Vol. 11 no. 1 (1), pp.55--77. ⟨10.46298/dmtcs.470⟩. ⟨hal-00988182⟩
Collections
TDS-MACS
56 Consultations
748 Téléchargements
