On the length of shortest 2-collapsing words - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2009
Given a word w over a finite alphabet Sigma and a finite deterministic automaton A = < Q,Sigma,delta >, the inequality vertical bar delta(Q,w)vertical bar <= vertical bar Q vertical bar - k means that under the natural action of the word w the image of the state set Q is reduced by at least k states. The word w is k-collapsing (k-synchronizing) if this inequality holds for any deterministic finite automaton ( with k + 1 states) that satisfies such an inequality for at least one word. We prove that for each alphabet Sigma there is a 2-collapsing word whose length is vertical bar Sigma vertical bar(3)+6 vertical bar Sigma vertical bar(2)+5 vertical bar Sigma vertical bar/2. Then we produce shorter 2-collapsing and 2-synchronizing words over alphabets of 4 and 5 letters.
983-4060-3-PB.pdf (157.55 Ko) Télécharger le fichier
hal-00988185 , version 1 (07-05-2014)
Alessandra Cherubini, Andrzej Kisielewicz, Brunetto Piochi. On the length of shortest 2-collapsing words. Discrete Mathematics and Theoretical Computer Science, 2009, Vol. 11 no. 1 (1), pp.33--44. ⟨10.46298/dmtcs.463⟩. ⟨hal-00988185⟩
Collections
TDS-MACS
60 Consultations
765 Téléchargements
