Nonhomogeneous nilpotent approximations for systems with singularities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2004
Marilena Vendittelli
  • Fonction : Auteur
Giuseppe Oriolo
  • Fonction : Auteur
Frédéric Jean
Jean-Paul Laumond
  • Fonction : Auteur
  • PersonId : 841546
Nilpotent approximations are a useful tool for analyzing and controlling systems whose tangent linearization does not preserve controllability, such as nonholonomic mechanisms. However, conventional homogeneous approximations exhibit a drawback: in the neighborhood of singular points (where the system growth vector is not constant) the vector fields of the approximate dynamics do not vary continuously with the approximation point. The geometric counterpart of this situation is that the sub-Riemannian distance estimate provided by the classical Ball-Box Theorem is not uniform at singular points. With reference to a specific family of driftless systems, we show how to build a nonhomogeneous nilpotent approximation whose vector fields vary continuously around singular points. It is also proven that the privileged coordinates associated to such an approximation provide a uniform estimate of the distance.
Fichier non déposé
hal-00988934 , version 1 (09-05-2014)
Marilena Vendittelli, Giuseppe Oriolo, Frédéric Jean, Jean-Paul Laumond. Nonhomogeneous nilpotent approximations for systems with singularities. IEEE Transactions on Automatic Control, 2004, 49 (2), pp.261-266. ⟨10.1109/TAC.2003.822872⟩. ⟨hal-00988934⟩
Collections
ENSTA UMA_ENSTA
68 Consultations
0 Téléchargements
