Solution of axisymmetric Maxwell equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Methods in the Applied Sciences Année : 2003
Franck Assous
Simon Labrunie
  • Fonction : Auteur
  • PersonId : 935115
In this article, we study the static and time-dependent Maxwell equations in axisymmetric geometry. Using the mathematical tools introduced in (Math. Meth. Appl. Sci. 2002; 25: 49), we investigate the decoupled problems induced in a meridian half-plane, and the splitting of the solution in a regular part and a singular part, the former being in the Sobolev space H1 component-wise. It is proven that the singular parts are related to singularities of Laplace-like or wave-like operators. We infer from these characterizations: (i) the finite dimension of the space of singular fields; (ii) global space and space-time regularity results for the electromagnetic field. This paper is the continuation of (Modél. Math. Anal. Numér. 1998; 32: 359, Math. Meth. Appl. Sci. 2002; 25: 49). Copyright © 2003 John Wiley & Sons, Ltd.
hal-00989564 , version 1 (12-05-2014)
Franck Assous, Patrick Ciarlet, Simon Labrunie. Solution of axisymmetric Maxwell equations. Mathematical Methods in the Applied Sciences, 2003, 26 (10), pp.861-896. ⟨10.1002/mma.400⟩. ⟨hal-00989564⟩
89 Consultations
0 Téléchargements
