On the analysis of Bérenger's perfectly matched layers for Maxwell's equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2002
In this work, we investigate the Perfectly Matched Layers (PML) introduced by Bérenger [3] for designing efficient numerical absorbing layers in electromagnetism. We make a mathematical analysis of this model, first via a modal analysis with standard Fourier techniques, then via energy techniques. We obtain uniform in time stability results (that make precise some results known in the literature) and state some energy decay results that illustrate the absorbing properties of the model. This last technique allows us to prove the stability of the Yee's scheme for discretizing PML's.
hal-00990161 , version 1 (13-05-2014)
Eliane Bécache, Patrick Joly. On the analysis of Bérenger's perfectly matched layers for Maxwell's equations. ESAIM: Mathematical Modelling and Numerical Analysis, 2002, 36 (1), pp.87-119. ⟨10.1051/m2an:2002004⟩. ⟨hal-00990161⟩
151 Consultations
0 Téléchargements
