Acoustic diffraction by a rigid plate in a uniform flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2002
Lynda Dahi
  • Fonction : Auteur
Vincent Pagneux
We present a mathematical framework for the problem of the acoustic diffraction by a plate located in a duct, in the presence of a uniform flow. The model is based on a velocity potential representation outside a vortex sheet which is induced by the trailing edge of the plate. Using limiting absorption techniques and singular functions decompositions, we show how to get a theoretical and numerical well-suited formulation.
Fichier non déposé
hal-00990309 , version 1 (13-05-2014)
Anne-Sophie Bonnet-Ben Dhia, Lynda Dahi, Éric Lunéville, Vincent Pagneux. Acoustic diffraction by a rigid plate in a uniform flow. Mathematical Models and Methods in Applied Sciences, 2002, 12 (5), pp.625-647. ⟨10.1142/S0218202502001829⟩. ⟨hal-00990309⟩
160 Consultations
0 Téléchargements
