Asymptotics of the Stirling numbers of the first kind revisited: A saddle point approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2010
Using the saddle point method, we obtain from the generating function of the Stirling numbers of the first kind [n j] and Cauchy's integral formula, asymptotic results in central and non-central regions. In the central region, we revisit the celebrated Goncharov theorem with more precision. In the region j = n - n(alpha); alpha > 1/2, we analyze the dependence of [n j] on alpha.
1308-5002-1-PB.pdf (329.07 Ko) Télécharger le fichier
hal-00990462 , version 1 (13-05-2014)
Guy Louchard. Asymptotics of the Stirling numbers of the first kind revisited: A saddle point approach. Discrete Mathematics and Theoretical Computer Science, 2010, Vol. 12 no. 2 (2), pp.167-184. ⟨10.46298/dmtcs.501⟩. ⟨hal-00990462⟩
Collections
TDS-MACS
49 Consultations
920 Téléchargements
