The largest singletons in weighted set partitions and its applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2011
Recently, Deutsch and Elizalde studied the largest fixed points of permutations. Motivated by their work, we consider the analogous problems in weighted set partitions. Let A (n,k) (t) denote the total weight of partitions on [n + 1] = \1,2,..., n + 1\ with the largest singleton \k + 1\. In this paper, explicit formulas for A (n,k) (t) and many combinatorial identities involving A (n,k) (t) are obtained by umbral operators and combinatorial methods. In particular, the permutation case leads to an identity related to tree enumerations, namely, [GRAPHICS] where D-k is the number of permutations of [k] with no fixed points.
1766-6688-1-PB.pdf (320.04 Ko) Télécharger le fichier
hal-00990479 , version 1 (13-05-2014)
Yidong Sun, Yanjie Xu. The largest singletons in weighted set partitions and its applications. Discrete Mathematics and Theoretical Computer Science, 2011, Vol. 13 no. 3 (3), pp.75--86. ⟨10.46298/dmtcs.535⟩. ⟨hal-00990479⟩
Collections
TDS-MACS
33 Consultations
914 Téléchargements
