Colouring the Square of the Cartesian Product of Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2011
We prove upper and lower bounds on the chromatic number of the square of the cartesian product of trees. The bounds are equal if each tree has even maximum degree.
1697-6418-1-PB.pdf (173.63 Ko) Télécharger le fichier
hal-00990503 , version 1 (13-05-2014)
David R. Wood. Colouring the Square of the Cartesian Product of Trees. Discrete Mathematics and Theoretical Computer Science, 2011, Vol. 13 no. 2 (2), pp.109--111. ⟨10.46298/dmtcs.549⟩. ⟨hal-00990503⟩
Collections
TDS-MACS
37 Consultations
889 Téléchargements
