Integrating Adaptation Mechanisms Using Control Theory Centric Architecture Models: A Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Control theory provides solid foundations for developing reliable and scalable feedback control for software systems. Although, feedback controllers have been acknowledged to efficiently solve common classes of problems, their adoption by state-of-the-art approaches for designing self-adaptation in legacy software systems remains limited and at best consists in ad hoc integrations, which are usually engineered manually. In this paper, we revisit the Znn.com case study and we present an alternative implementation based on classical feedback controllers. We show how these controllers can be easily integrated into software systems through control theory centric architecture models and domain-specific modeling support. We also provide an assessment of the resulting properties, quality attributes and limitations.
icac14-paper.pdf (263.93 Ko) Télécharger le fichier
hal-00991114 , version 1 (23-05-2014)
hal-00991114 , version 2 (19-06-2014)
  • HAL Id : hal-00991114 , version 2
Filip Krikava, Philippe Collet, Romain Rouvoy. Integrating Adaptation Mechanisms Using Control Theory Centric Architecture Models: A Case Study. ICAC - 11th International Conference on Autonomic Computing, USENIX, Jun 2014, Philadelphia, United States. ⟨hal-00991114v2⟩
356 Consultations
219 Téléchargements
