Combined Visible and X-Ray 3D Imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Julien Pansiot
Lionel Reveret
Edmond Boyer
This paper considers 3D imaging of moving objects and introduces a technique that exploits visible and x-ray images to recover dense 3D models. While recent methods such as tomography from cone-beam x-ray can advantageously replace more expensive and higher-dose CT scanners, they still require specific equipment and immobilised patients. We investigate an alternative strategy that combines a single x-ray source and a set of colour cameras to capture rigidly moving samples. The colour cameras allow for coarse marklerless motion tracking, which is further refined with the x-ray information. Once the sample poses are correctly estimated, a dense 3D attenuation model is reconstructed from the set of x-ray frames. Preliminary results on simulated data compared to ground-truth as well as actual in-vivo experiments are presented.
2014_Pansiot_MIUA_Xrays.pdf (2.17 Mo) Télécharger le fichier
Format : Figure, Image
hal-00994974 , version 1 (08-12-2014)
  • HAL Id : hal-00994974 , version 1
Julien Pansiot, Lionel Reveret, Edmond Boyer. Combined Visible and X-Ray 3D Imaging. Medical Image Understanding and Analysis, Jul 2014, London, United Kingdom. pp.13-18. ⟨hal-00994974⟩
556 Consultations
681 Téléchargements
