Kevoree Modeling Framework (KMF): Efficient modeling techniques for runtime use - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
The creation of Domain Specific Languages(DSL) counts as one of the main goals in the field of Model-Driven Software Engineering (MDSE). The main purpose of these DSLs is to facilitate the manipulation of domain specific concepts, by providing developers with specific tools for their domain of expertise. A natural approach to create DSLs is to reuse existing modeling standards and tools. In this area, the Eclipse Modeling Framework (EMF) has rapidly become the defacto standard in the MDSE for building Domain Specific Languages (DSL) and tools based on generative techniques. However, the use of EMF generated tools in domains like Internet of Things (IoT), Cloud Computing or Models@Runtime reaches several limitations. In this paper, we identify several properties the generated tools must comply with to be usable in other domains than desktop-based software systems. We then challenge EMF on these properties and describe our approach to overcome the limitations. Our approach, implemented in the Kevoree Modeling Framework (KMF), is finally evaluated according to the identified properties and compared to EMF.
KevoreeModelingFramework.pdf (466.92 Ko) Télécharger le fichier
hal-00996764 , version 1 (26-05-2014)
François Fouquet, Grégory Nain, Brice Morin, Erwan Daubert, Olivier Barais, et al.. Kevoree Modeling Framework (KMF): Efficient modeling techniques for runtime use. [Research Report] TR-SnT-2014-11, University of Luxembourg. 2014, pp.24. ⟨hal-00996764⟩
916 Consultations
941 Téléchargements
