Expressiveness via Intensionality and Concurrency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thomas Given-Wilson
  • Fonction : Auteur
  • PersonId : 955938
Computation can be considered by taking into account two dimensions: extensional versus intensional, and sequential versus concurrent. Traditionally sequential extensional computation can be captured by the lambda-calculus. However, recent work shows that there are more expressive intensional calculi such as SF-calculus. Traditionally process calculi capture computation by encoding the lambda-calculus, such as in the pi-calculus. Following this increased expressiveness via intensionality, other recent work has shown that concurrent pattern calculus is more expressive than pi-calculus. This paper formalises the relative expressiveness of all four of these calculi by placing them on a square whose edges are irreversible encodings. This square is representative of a more general result: that expressiveness increases with both intensionality and concurrency.
compute.pdf (133.68 Ko) Télécharger le fichier
hal-00999082 , version 1 (03-06-2014)
Thomas Given-Wilson. Expressiveness via Intensionality and Concurrency. ICTAC 2014 - 11th International Colloquium on Theoretical Aspects of Computing, Sep 2014, Bucharest, Romania. pp.206-223, ⟨10.1007/978-3-319-10882-7_13⟩. ⟨hal-00999082⟩
313 Consultations
125 Téléchargements
