An ACG View on G-TAG and Its g-Derivation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
G-TAG is a Tree Adjoining Grammar (TAG) based formalism which was specifically designed for the task of text generation. Contrary to TAG, the derivation structure becomes primary, as pivot between the conceptual representation and the surface form. This is a shared feature with the encoding of TAG into Abstract Categorial Grammars. This paper propose to study G-TAG from an ACG perspective. We rely on the reversibility property of ACG that makes both parsing and generation fall within a common morphism inversion process. Doing so, we show how to overcome some limitations of G-TAG regarding predicative adjunction and how to propose alternative approaches to some phenomena.
LacL2014.pdf (159.34 Ko) Télécharger le fichier
hal-00999633 , version 1 (03-06-2014)
Laurence Danlos, Aleksandre Maskharashvili, Sylvain Pogodalla. An ACG View on G-TAG and Its g-Derivation. Logical Aspects of Computational Linguistics: 8th International Conference, LACL 2014, Toulouse, France, June 18-20, 2014. Proceedings, Jun 2014, Toulouse, France. pp.70-82, ⟨10.1007/978-3-662-43742-1_6⟩. ⟨hal-00999633⟩
246 Consultations
360 Téléchargements
