A Distributed Solution to the Network Reconstruction Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2014
Fabio Morbidi
Alain Kibangou
It has been recently shown in Ren et al. (2010) that by collecting noise-contaminated time series generated by a coupled-oscillator system at each node of a network, it is possible to robustly reconstruct its topology, i.e. determine the graph Laplacian. Restricting ourselves to linear consensus dynamics over undirected communication networks, in this paper we introduce a new dynamic average consensus least-squares algorithm to locally estimate these time series at each node, thus making the reconstruction process fully distributed and more easily applicable in the real world. We also propose a novel efficient method for separating the off-diagonal entries of the reconstructed Laplacian, and examine several concepts related to the trace of the dynamic correlation matrix of the coupled single integrators, which is a distinctive element of our network reconstruction method. The theory is illustrated with examples from computer, power and transportation systems.
Automatique
MoKi_SCL14.pdf (537.38 Ko) Télécharger le fichier
hal-01001828 , version 1 (05-06-2014)
Fabio Morbidi, Alain Kibangou. A Distributed Solution to the Network Reconstruction Problem. Systems and Control Letters, 2014, 70, pp.85-91. ⟨10.1016/j.sysconle.2014.05.008⟩. ⟨hal-01001828⟩
341 Consultations
540 Téléchargements
