Sliding Mode Control Design for MIMO Systems: Implicit Lyapunov Function Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new approach to robust control design is considered. It is based on Implicit Lyapunov Function method. An algorithm of robust finite-time stabilization for a quasi- linear multi-input disturbed system is developed. A new high- order sliding mode control algorithm is deduced. Procedures for tuning of control parameters are presented. They are based on Linear Matrix Inequalities (LMI). Aspects of practical implementation of developed algorithms are discussed. A scheme for chattering reduction is proposed. Theoretical results are supported by numerical simulations.
Automatique
main.pdf (149.31 Ko) Télécharger le fichier
hal-01003984 , version 1 (11-06-2014)
  • HAL Id : hal-01003984 , version 1
Andrey Polyakov, Denis Efimov, Wilfrid Perruquetti. Sliding Mode Control Design for MIMO Systems: Implicit Lyapunov Function Approach. European Control Conference, IEEE, IFAC, Jun 2014, Strasbourg, France. ⟨hal-01003984⟩
273 Consultations
2377 Téléchargements
