Compositionality Results for Quantitative Information Flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the min-entropy approach to quantitative information flow, the leakage is defined in terms of a minimization problem, which, in case of large systems, can be computationally rather heavy. The same happens for the recently proposed generalization called g-vulnerability. In this paper we study the case in which the channel associated to the system can be decomposed into simpler channels, which typically happens when the observables consist of several components. Our main contribution is the derivation of bounds on the g-leakage of the whole system in terms of the g-leakage of its components.
QEST2014long.pdf (365.47 Ko) Télécharger le fichier
hal-01006381 , version 1 (16-06-2014)
hal-01006381 , version 2 (16-06-2014)
Yusuke Kawamoto, Konstantinos Chatzikokolakis, Catuscia Palamidessi. Compositionality Results for Quantitative Information Flow. Proceedings of the 11th International Conference on Quantitative Evaluation of SysTems (QEST 2014), Sep 2014, Florence, Italy. pp.368-383, ⟨10.1007/978-3-319-10696-0⟩. ⟨hal-01006381v2⟩
378 Consultations
417 Téléchargements
